Ricoh 1035
  • tcypy1961
    • 773
    Ricoh 1035
    Copier was in flood. Damage appeared to be in lower paper feed deck, which was replaced. Was called out to service copier for misfeeding - problem appeared to be from wet paper. Noticed copier making beeping noise that is usually heard after a misfeed or SC error code or when a door has been opened; none of these appear when noise is made. There appears to be no reason for beeping noise. Nothing appears on display. Any suggestions?
    Thanks!!!
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Ricoh 1035
    Thanks!!!
    Copier was in a flood, have the insurance company replace it. It will never be the same.
    Testing 1-2-3, testing, testing. Is this thing on?
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      Re: Ricoh 1035
      Copier was in flood. - problem appeared to be from wet paper.
      Thanks!!!
      my post wont help you but the above quote - thats classic!
      Incontinentia Buttocks
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Ricoh 1035
        Have the lower cover switches been changed? A door open message gives a similar beep.
        Hit it.
        • Gift
          • Mar 2011
          • 2459
          Re: Ricoh 1035
          Maybe there's moisture inside the operation panel causing false key triggers.
          • Eric1968
            • 2458
            Re: Ricoh 1035
            Had the same a few years ago with an Aficio 3228C. Machine gave beeps at random moments. Turned out to be the control panel.
            • Shadow1
              • Sep 2008
              • 1642
              Re: Ricoh 1035
              These machines are famous for door switches going bad under the best of circumstances (esp. the finishers (any model finisher)) Water and the resulting high humidity can't have helped that. You'll get strange beeps and random paper jams - most of which the tech sees as J001 which is paper in path at power on.
              73 DE W5SSJ
