Does multifunction printer can print via like a vpn connection
  • Gesttech
    • Oct 2009
    • 123
    [Misc] Does multifunction printer can print via like a vpn connection
    HI
    i have a client that has a Ricoh mp4001 & They wanted to print from their home to the office.
    Does ricoh has this option. What option to used?
    For me i suggest the client to used a VPN connection. What does you advice me?
    Help Pls
  • Jomama46
    • 2900
    Re: Does multifunction printer can print via like a vpn connection
    Set up an IPP connection on the server and print to that.
    sigpic
    A+; Network +; PDI+
    • Gesttech
      • Oct 2009
      • 123
      How to set an ipp connection on the server Jomama46
      i dont know.
      Thank
      • Jomama46
        • 2900
        Its been a long time since I did one, Better you should Google it.
        sigpic
        A+; Network +; PDI+
        • TheOwl
          • Nov 2008
          • 1731
          VPN connection would be the best idea, but you can also use IPP or you could even forward port 9100 from the router to the printer so that when you print to the IP address of the business (real world internet IP address) using port 9100, all that information will be forwarded to the copier.
          • Llama God
            • Mar 2009
            • 1353
            I agree, a VPN tunnel using RDP would be the best answer. The customer would normally get their IT people to sort this out for them, ideally using a public-facing static IP address.
            The alternative, I suppose, would be to set up IP address translation on their firewall from a static public-facing IP address to the local IP address of the copier, but that would just be silly.
