Problem with Lanier LD132C
  • copy.eva
    • Jun 2012
    • 33
    When I turn on the copier on the panel display appears that all toner cartridges are not set properly, but I'm sure that I have set them correctly...tnx
  • Jomama46
    • 2900
    Re: Problem with Lanier LD132C
    What the heck is a LD132c. Product code would be helpful. Maybe you have the wrong toner installed. What happened just before you observed this phenomena?
    sigpic
    A+; Network +; PDI+
      • 22999
      OEM or generic crap? =^..^=
      • nmfaxman
        • 1702
        Has to be refills.
        Ask Aab1 how well that works.
        • copy.eva
          • Jun 2012
          • 33
          Lanier LD132C is the same with Aficio 1232C
          • Jomama46
            • 2900
            ok so there's your problem right there. Beside that the Lanier equivalent is LD032C. Is is a refill? They don't work and even if they did, this copier is one of the worst machines ever. Dont worry about the toner. just run!
            sigpic
            A+; Network +; PDI+
