Have you seen this ?
  • NeoMatrix
    Senior Tech.
    • 3514
    Anyone seen this before ?
    Ricoh MPC3500 Yellow PCU charge roller has a lable stuck to it.
    What are the odds ?
    Made some great and interesting effects on the I.T.B.
    • 22932
    Re: Have you seen this ?
    Doncha just love labels?
    "What's the best kind of labels to run?"
    "None. That's preferable." =^..^=
    • Llama God
      • Mar 2009
      • 1353
      What are the odds ?
      [ATTACH=CONFIG]16610[/ATTACH]
      Did you charge them for this? Get it? Charge? Anyone?
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 418
        • NeoMatrix
          Senior Tech.
          • 3514
          I'm a bit of a softy, first time is usually a warning. It never seems to happen a second time though.
          The other tech's recond it has something to do with the baseball bat I hit against my left hand as explain the fault to customer. And I don't even know how to play baseball....(Just Kidding).
          Labels definitely push the friendships though...
            • 22932
            I'm sure you already know this ... but most address labels are designed to be fed in the Letter-R direction, not Letter, and always from the bypass or MP tray with the proper media settings. The Avery labels are marked with a feed direction in the margin of the page.
            Just from that picture I know that page was fed in the Letter direction. Like you, the warning doesn't cost, but it's noted on the service report and billed the second and any number of times in the future.
            • Hansoon
              • Sep 2007
              • 3349
              But this becomes all obsolete when customer re-runs sheets with partially unused labels......
              Hans
              “ Sent from my Intel 80286 using MS-DOS 2.0
              https://www.copytechnet.com/images/smilies/biggrin.png
              • Gift
                • Mar 2011
                • 2444
                I also tell my customers that it's not allowed (or that any problems are covered by the service sontract) if they try to re-use any incomplete label sheetd since the risk that something peels of is gaining once they have removed one or more labels. Usually I suggest to purchase some kind of Dymo/Brother/Whatever Label printer - these are usually stress-free and you can print single or multiple labels without issues. These devices are cheap and the labels are cheap as well (if you buy compatible ones).
                • NeoMatrix
                  Senior Tech.
                  • 3514
                  Re Labels....
                  It's sh!ts me to tears when the customer says " The salesman sold us this machine on the condition it would print on slabs of concrete and sheets of bulletproof glass. " Yerrr rrrriggght... Love those salesman (sales-persons).
                  • mrwho
                    Major Asshole!
                    • 4299
                    I believe you're not kidding - I don't know how to play baseball either!
                    Mascan42
                    Ibid
