admin pword protect for print on mpc6000
  • digicor
    • Jul 2008
    • 1159
    How do i enable the pw protect for print at the pc? I have it all set up at the machine for user tracking,but i cant seem to get the pop up for print for user tracking? ive enabled all the admin user rights that i thought i needed to, do i need a diff driver for this feature?
  • kyrenecopy
    • Apr 2012
    • 205
    Re: admin pword protect for print on mpc6000
    Don't know if this will help, let me know
    Testing 1-2-3, testing, testing. Is this thing on?
    • Llama God
      • Mar 2009
      • 1353
      If you want to use a pop-up for user codes when you print then you'll need to use the print driver editor.
      Alternatively you can embed a code into the driver on each PC if you wish.
      • digicor
        • Jul 2008
        • 1159
        Thanks Guys
        Im sure this will fix it, i remember using it in a server environment before but i just thought it was part of all the driver features
        • FMC
          • Aug 2008
          • 88
          Remember if you edit the driver it is no longer windows safe certified, so there IT may take issue with it.
