Aficio 3035 & 2035e DMU
  • aficiouser
    • May 2025
    Hey guys,
    I got this drum master unit which is printing very dirty and toner are spills all over.I did emptied the unit,clean it up and now it's printing very cleaned but a blank output.Did i do wrong to clean up the drum unit? could i directly put toner on the drum unit?
    Thanks.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Make sure the drum unit is pushed in all the way.
    Failing that check the charge roller and the metal contacts and bushings.
    • SGT_Snacks-64
      • Oct 2007
      • 157
      Originally posted by aficiouser
      Hey guys,
      Thanks.
      What.... the..... hell........ is a Drum Master Unit? :S
      Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
      Asus P5E-VM HDMI
      4GB (2x 2GB) Corsair XMS Xpert II RAM
      ATi Radeon 4870 512MB GFX Card
      2x 74GB WD Raptor Sata HDD (RAID 0)
      500GB Seagate Barracuda Sata II HDD
      500GB Hitachi Sata II HDD
      600W500att OCZ PSU
      -TOTAL HDD SPACE 1148GB-
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 418
        Hey guys,
        Thanks.
        When you say you emptied the unit......
        Did you empty out the PCU? I.E the toner in the recycling unit behind the cleaning blade?
        Or did you empty out the development unit?
        Because if you emptied out the development unit I wouldn't be too surprised if you're getting blank copies.
        • SGT_Snacks-64
          • Oct 2007
          • 157
          Yeah Developer and Toner are very different things, you can feel the texture of Developer and the texture of Toner in your fingers, Developer has a slightly gritty feel to it. If you've hoovered all the Dev out, you'll have to put some more in there. The Part number for Developer, if you need it, is
          Developer Type 26 Black: B079 9640
          If you have the Service Manual "And if you're actually a Service Engineer, you'll have this", it'll give you clear instructions on all the steps to do this.
          If you're not sure, the Developer carries Toner onto the Drum through the Mag Roller, which is why the Developer is so important, filling the Developer Unit with Toner won't produce any results "Or you might find dirty copies again" Which answers your question, you can't put Toner directly onto the Drum.
          Just out of Curiosity, have you checked the Toner Sheild Glass? If Toner's got all over this it won't allow the Laser to discharge the Drum, which would give you blank copies, just worth a check if anything.
          Hope this helps!
          Asus P5E-VM HDMI
          600W500att OCZ PSU
          • aficiouser
            Yep I did clear out the developer unit and i don't know how to
            refill it..its been a while now that this machine is broken,printing
            blank pages...is there anyone can help me for the procedure to
            refill the developer unit?
            your help is much appreciated.Thanks!
            • SGT_Snacks-64
              • Oct 2007
              • 157
              This Proceedure, like all other replacement proceedures for these machines is outlined in the Service Manual under "Replacement and Adjustment"
              Now, a Service Engineer will have the Service Manual. If you don't have it, then I suggest you get someone in there to replace the developer.
              Hope this helps.
              Asus P5E-VM HDMI
              600W500att OCZ PSU
              • aficiouser
                SGT_Snacks,thanks for your suggestion but service engineer in
                my area doesn't exists...just bought a new developer unit and
                of course it's empty.
                btw,the machine is working perfectly if i use another developer unit
                from other running machine.
                i hope someone could help me to sort this out.
                Thanks again.
                Hope this helps.
                • Jimbo1
                  • Mar 2008
                  • 845
                  You have to put developer material in that developer unit.
                  Period, That's all that will solve your problem.
                  But you better get a manual from somenone to get the code to run after or you will still have problems.
                  "Some days you get the bear, some days the bear gets you."
                  Cdr. William Riker
                  • aficiouser
                    thanks jimbo1...are you saying i have to buy a refill kit,after refilling the
                    developer unit i have to run some codes from the copier machine?.
                    sorry for the silly question.
                    • Jomama46
                      • 2900
                      Who services these other machines?
                      You are asking for trouble if you dont know what you're doing. And I think you dont.
                      sigpic
                      A+; Network +; PDI+
