ricoh aficio copying problem
  • RWAFA
    • Aug 2011
    • 68
    hi guys, i have got my ricoh aficio 2232c color,the machine is not copying,if i place a document for copying,the machine scans the document bt the copy doesnt come out,it shows the "copying" massage.if i dont cancel,it keeps on like that.at first it was producing error 552.does any 1 knows the problem pleas help.
  • Bantams
    • Jun 2012
    • 603
    Re: ricoh aficio copying problem
    Sounds like a Software Crash try power on/off and Update the Firmware
    Maybe Format the Hard Disk also.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Probably a bad fusing unit
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • ucinn
        • Jun 2009
        • 383
        Check your pressure roller lamp..probably open
        • Athlontini
          • Jun 2012
          • 269
          I just saw this issue/proposed solution in another thread. Try disconnecting the HDD; if it stops freezing after that then you know what the culprit probably is.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • wilez
              • Jan 2011
              • 55
              Remove controller and reseat memory also try printing internals(counter,configuration etc.) from user tools if the same occurs then step 2.
              Step 2 reformat HDD SP 5832.
              Step 3 will require new devs and pcu's plus writing all sp data, if unable to print it, but performing a sp 5810( i would start with printer,nib and system before doing and all)
              Hope this helps!
              https://t.me/pump_upp
              • rthonpm
                • Aug 2007
                • 2859
                SC 552 is a press roller warm up error so more than likely the fuser isn't reaching the proper temperature for printing. The fuser unit is fairly cheap to replace as a unit so try that and see what happens, especially if it's past PM yield.
