mpc3000 after refill tone rstill showing add toner sign
  • cva
    • Jul 2012
    • 23
    [CQ] mpc3000 after refill tone rstill showing add toner sign
    once add toner sign indicate :still showing add toner sign refill the toner also
  • Bantams
    • Jun 2012
    • 603
    Re: mpc3000 after refill tone rstill showing add toner sign
    Needs a New Modified Toner Pump Part Number is B223 3251
    • cva
      • Jul 2012
      • 23
      i have B223-3255 pump :issit can use
      • Bantams
        • Jun 2012
        • 603
        Perhaps Not sure I think that pump is for the printer Version wouldnt harm trying I suppose you can sometimes just vac out the old one but it would be only a tempory fix.
        It is quite common for the Black pumps to get blocked though we usually stock 4 of each the 2500 and 2800 ones in our stock
        • cva
          • Jul 2012
          • 23
          B223-3255 pump i was replaced but after repalce the pump the toner sign gone. now the almost empty message come out. really make me headache. anyway the machine running now
          • jivedancer
            • Apr 2011
            • 14
            toner pumps
            The toner pumps do cause issues on these models, mainly due to clutch problems, sometimes if you flush between the clutch plates with IPA and allow to dry, the pump can be refitted with no problem (Removes the oxidised powder that can form between the plates) carry a black pump for the model as the pipes tend to be longer on the black pump, if the pipe is split only option is too order the correct pump for the correct colour as the pipe has a sligthly wider neck just cutting off the end wont cure because you cant get the pipe to fit.
            • teebee1234
              • Jul 2008
              • 1670
              Probably due to the toner bottle changed out and back and the RFID chip is now invalid. Advise the customer to just ignore it, the machine will continue to function as long as it sees toner being added. Once the current bottle is empty and a new one is installed, the message will disappear.
