Password lost
  • hmac
    • Aug 2009
    • 129
    Password lost
    Hello,
    I have a DSc428 and an MP2550 with the client to change the administrator password and supervisor. But he does not remember more.
    The machines are locked.
    How to unlocked?
    For DSc428 I found in the service manual code SP-7-810-1, but when I go into SP mode there is not this code SP.
    There is there a code to bring up the code for SP.
    (eg as for the double counting -> # system SP)
    Thanks you in advance
    _________________
    HMac.
    _________________
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Password lost
    Originally posted by hmac
    Hello,
    How to unlocked?
    If they changed the supervisor password(which they shouldn't know about) your only hope is to reset the NCS (network control service)settings in sp mode. Other wise you'll be replacing the NVram.
    Mystic Crystal Revelations
    • zed255
      How'd ya manage that?
      • 1024
      Re: Password lost
      Do a search for 'factory mode' (sorry I will not tell you here) and run SP 5-846-46. This SP will only show in factory SP, not in normal or special SP.
      • JustManuals
        • Jan 2006
        • 9838
        Re: Password lost
        Paul@justmanuals.com
        • wilez
          • Jan 2011
          • 55
          Re: Password lost
          NVRAM! again NVRAM!!
          Order it save yourself the time of trying only to order the NVRAM.
          From experience this comes from!!
          https://t.me/pump_upp
          • zed255
            • 1024
            Re: Password lost
            Yes, replacing the NVRAM works just fine. Be sure to manually re-input the non-default data after initializing.
            I'm just pointing out that there is another option (there is actually another one yet again that is more involved as it related to an NVRAM data download, file modification and NVRAM upload). I will not divulge the factory SP mode here but it is already out on the 'net if someone wants to look for it. Running the appropriate SP will save much hassle. The other option is also outlined here on CTN.
