K+E 5800 drum cleaning blade issue
  • acsolutions
    • Jun 2010
    • 519
    [CQ] K+E 5800 drum cleaning blade issue
    Hello, I'm working on a K+E 5800 wide format machine you know the one with an easy bake oven for a fuser. (no rollers)
    It definitely has a cleaning blade issue but the thing is how do you remove the cleaning blade? I took the top cover off exposing led assy and developer and I see the drum with lines running through it. the copy has just lines no corona arcing so I just wanted to replace the drum blade. I lift up the top cover of the fuser and there is a plate that is spring loaded that is on the back of the process section I'm guessing it's behind their! Any help or literature would be greatly appreciated. Thanks
    The customer does not want to spend a lot of money, so were just going for the minimum.
  • teebee1234
    • 1670
    Re: K+E 5800 drum cleaning blade issue
    Never heard of that make/model. Are you posting in the right forum? This is Ricoh family products here.
