mpc3500 firmware?
  • digicor
    • Jul 2008
    • 1159
    mpc3500 firmware?
    customer changed the hdd in the machine,because the googled code said so... the internet is always right.. rite.. rigtj... trashed the old one not knowing it had "firmware" on it.. DUHHHH... so where can i down load some firmware for this machine? Im not an authorized ricoh dealer, this may be a problem? I guess i could clone a hdd from what i have already,but i was just wondering if its downloadable from some where. thanks
  • Eric1968
    • 2458
    Re: mpc3500 firmware?
    As far as I know there's no firmware on the HDD. What was the reason for replacing the HDD?
    • fbkhan3
      • May 2012
      • 421
      Firmware on HDD???that's something new to me,ain't it?
      • nmfaxman
        • 1702
        Just reformat the HDD in service mode.
        Reformatting installs current firmware on HDD from Nvram.
        • digicor
          • Jul 2008
          • 1159
          • Eric1968
            • 2458
            Sounds like the customer ruined the controller. When you replace the HDD after SC865, format the new HDD, you shouldn't get SC990's.
            • Llama God
              • Mar 2009
              • 1353
              Ditto, the firmware isn't on the hard drive in any way shape or form. You can prove this by unplugging the HDD cables and turning the machine on (it still works, mostly.)These HDDs have a form of RAID built in, therefore they have to be EXACTLY the same, not something a bit close.My advice would be to assess the machine, pull the end-user's pants down and give him a thorough thrashing.Stupid end-users...
              • sandmanmac
                • 3990
                Did they replace both HDD's or just one? And agree 100% with Llama, they must be a matched set (80Gb or larger), or they simply won't work
                • Llama God
                  • Mar 2009
                  • 1353
                  I agree with me too, although I'm frequently wrong.
                  • tcs04
                    FORMER Techie
                    • 1183
                    Also, Most IDE HDD's will have the jumpers set to "Cable select" as default. In this case the machine will not detect the drive(s) Reset the jumpers to "Master" and it may work.
