MP3350
  • Donk54
    • May 2025
    [CQ] MP3350
    recycle toner hopper is filled faster than is recycle back into toner hopper which causes black smudges on copy due to over fill
  • Eric1968
    • 2458
    Re: MP3350
    Development Unit is overtoned. Replace the Development Case and the two gears (white and black) attached to the Development Roller. Pour in a fresh bag of Developer and perform SP2-801.
    • WH007
      • 9
      Re: MP3350
      does the gears to the recycle auger mesh good, do you hear the gears chater and miss? i found the bushing that the auger went through had too much play allowing the gear mesh to seperate and even miss teeth.
      • Donk54
        Re: MP3350
        The Machine sounds good , no chatter,auger looks good, but will try a new auger. Thanks for the idea.
        • tcs04
          FORMER Techie
          • 1183
          Re: MP3350
          If the front of the dev unit is full of toner it may be the gears / auger. If not they are probably ok (They must be working to move the toner / dev from the inlet of the dev unit). If you put new dev in, make sure you put paper between the pcu and dev unit where the toner feeds during set up or you may feed toner from the hopper / toner recycle which will immediately overtone the new dev and result in the same problem. What is the VT / VSP reading before changing the dev?
          • Donk54
            Re: MP3350
            Recycle auger was warped causing the problem
            Thanks again.
            • tcs04
              FORMER Techie
              • 1183
              Re: MP3350
              Thanks again.
              Auger in dev unit? What caused the warp? overfill? if so I would still check the VT / Vsp readings and adjust as required.
              • Donk54
                Re: MP3350
                Toner recycle coil was warpped, Top half of the PCU was starting to wear out , M/C has 640K on it.
                Thanks again for the ideas to check.
                • JustManuals
                  • Jan 2006
                  • 9838
                  Re: MP3350
                  http://www.justmanuals.com
                  Paul@justmanuals.com
