RICOH MP C4500 dark background color in copying
  • tecnomarco
    • Jul 2011
    • 209
    Greetings to you, I have the following problem on a Ricoh MP C4500, making color copies with automatic mode, or full color, there is a dark background, making copies black / white copies are normal automatic exposure bottomless dark somebody can tell me that I can control, or you have to replace any parts, thank you for your attention
  • ptrflrs
    Glorified Parts Swapper
    • Dec 2010
    • 192
    Re: RICOH MP C4500 dark background color in copying
    if i understand right u r getting dark on the bottom or top of pages which usually is the charge roller dirty, clean with soft cloth and very little water and allow to dry completely. i'm sure you checked optics and laser slits clean?
    jesus loves you! (everyone else thinks you're an assh*le)
    street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
    Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
    • tecnomarco
      • Jul 2011
      • 209
      black and white copies are good, the printing of the test color is good, making a color copy there is a uniform background of all the press seems to have adjusted to the maximum dark
      • fbkhan3
        • May 2012
        • 421
        Are you getting print right? does it only happen with copies?if so then make sure you got the mirrors,ARDF mayler,and scanning glass clean. if it doesn't help you out try to lift the scanner from left front.it normally gets bent with a push and create some weird problems like background or lines in copies! good luck!
        • tecnomarco
          • Jul 2011
          • 209
          to explain, printing and copying is good, this fund is clear, it seems a problem of automatic exposure, adjusting manually to clear up the bottom disappears
          • Llama God
            • Mar 2009
            • 1353
            There's some sort of adjustment in SP4xxx for coloured backgrounding but I can't remember what it is. Get the birth certificate out and check your settings.Out of interest, have you replaced the NVRAM recently?
            • tecnomarco
              • Jul 2011
              • 209
              is a photocopier purchased a few days ago, I do not think has been replaced the nvram
              • Llama God
                • Mar 2009
                • 1353
                Replacing the NVRAM can cause some odd backgrounding faults. Anyway, back to SP4xxx for you...
                • tecnomarco
                  • Jul 2011
                  • 209
                  Can you remember which SP4xxx
                  • teebee1234
                    • Jul 2008
                    • 1670
                    Llama God is on the right track. The grayscale setting has reset to default value. Not sure of the exact sp, just check the factory data sheet against what is currently programmed.
                    • Llama God
                      • Mar 2009
                      • 1353
                      No, otherwise I would have told you.
                      • tecnomarco
                        • Jul 2011
                        • 209
                        I double checked the values ​​shown on the certificate of the car and as you say the gray scale was calibrated throughout - still 240 problem solved thanks to god and llama Teebee 1234
                        • Llama God
                          • Mar 2009
                          • 1353
                          We are the kings of the night time world, as Kiss would say.
