Ricoh Aficio 1022
  • tcypy1961
    • 773
    Ricoh Aficio 1022
    What else besides the drum, drum blade, and charge roller would cause a line down the copy in this Ricoh Aficio 1022? The line shows up no matter if I lay it on the glass or run it through the feeder. Any help appreciated, thank you.
  • ss12
    • Jul 2008
    • 289
    Try cleaning the laser slit glass
    • Eric1968
      • 2458
      Re: Ricoh Aficio 1022
      Maybe a scratch on the Hot Roller?
      • copyaction
        • Oct 2007
        • 985
        Does it show up when you print a counter sheet?
        • tcs04
          FORMER Techie
          • 1183
          white line? Black line? Prints, copies or both? (as mentioned) If copies confirm by placing a "large" (A3 size) original on the ADF, select "Auto reduce /enlarge) and copy to tray 1 using A4 (Or similar) LEF. This will rotate the line across the feed direction and confirm optics / scanning as the issue.
            • 22973
            Lint on light source #1 (mirror #1), or on the CCD lens?
            • kyrenecopy
              • Apr 2012
              • 205
              White line: dirty laser sight glass
              Black line: fuser roller or developer unit, piece of lint/dirt hanging in drum area touching drum, transfer assy/belt
              Testing 1-2-3, testing, testing. Is this thing on?
