MP c2800 fuser Fan and IOB blow after a week
  • trebor
    • Aug 2025
    [Electrical] MP c2800 fuser Fan and IOB blow after a week
    Hello all . I have just replaced the IOB and fuser fan for the third time in 2 months. the error is sc535 with the fuser fan dead. replacing the fan only does nothing , replacing the iob and fan works for a week.
    I suspect that something is making the fan switch on constantly , the excess current takes out both items. I have changed the psu this time and am waiting the outcome over the next few days.
    Has anyone seen anything similar? or got any light to shed?
    cheers
  • Bantams
    • Jun 2012
    • 603
    Re: MP c2800 fuser Fan and IOB blow after a week
    Was the Old fan actually Broken or Just the IOB?
    I would replace the PSU with the new modified one as a start thoughpart number AZ24-0195. If its still blowing the IOB after that Check for damaged wires especially ones from the fan to the IOB.
    • trebor
      The fan had stopped working , fit it back after changing the IOB and nothing , New Fan ok. ~It could be a trapped wire but with it having "normal operation" switching on and off with temp it's not likely but i have removed the fan IOB harness and phyically checked it , even added insulation through the frame. I'm hoping it is the PSU as its not the IOB.
