Ricoh 1045 - tripping power
  • daveh12
    • Jul 2012
    • 157
    [Electrical] Ricoh 1045 - tripping power
    hi,
    I am having trouble with a Ricoh 1045 tripping the power whenever it is powered ON. Checked Power Supply Board and replaced but problem persists. Any suggestions appreciated..
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Ricoh 1045 - tripping power
    Tripping the power when you turn it on means that you have a short in a 110v line. Most obvious is the fuser has pinched wires or bare wires on the lamps or a shorted thermofuse to the fuser roller. Other possibility is a bad power supply or worn wires at the plug. Shorts in the 24v and 5v lines would normally not cause the wall plug breaker to pop. Also check your door switches, they are famous for having problems. Any sorter, document feeder, paper tray etc add on should be disconnected from main machine to isolate them as a cause. Good luck.
    Testing 1-2-3, testing, testing. Is this thing on?
    • fbkhan3
      • May 2012
      • 421
      Has there been another tech on this machine before you?if not then X2 on (kyrenecopy) post. this way it'll surely sort it out. I would first start with Bad Fuser option.
      • ucinn
        • Jun 2009
        • 383
        Originally posted by daveh12
        hi,
        another thing to check would be in the interchange unit. Right up there with the exit sensor, the wonderful engineers decided to run a wire for an extra sensor right across a metal shaft which then shorts out. Check that along with the fuser.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • daveh12
            • Jul 2012
            • 157
            thanks, will let you know how i get on.
            • ccchuah
              • Mar 2009
              • 157
              Replace the fuser unit thermostat holder housing B004-4105
                • 23009
                I'm going to mention this just because noone else has: Is it possible that the circuit is already overloaded, and the Ricoh is just the straw that broke the camel's back? =^..^=
                • nmfaxman
                  • 1702
                  Measure neutral to ground with copier unplugged. Should be .5 or less. The higher the voltage, the more load on the circuit. Find out what else is dead when breaker blows.
                  • Boonboon
                    Fuser unit -Problem lies on the thermostat housing
                    • Llama God
                      • Mar 2009
                      • 1353
                      Fuser unit, it's always the fuser unit.
                      Unplug the duplex, ADF, system stand and remove the fuser, check that the machine powers up fine with them all disconnected, then turn it back on after plugging each one in, one at a time.
                      Do the fuser last - it'll be the fuser.
                      • Llama God
                        • Mar 2009
                        • 1353
                        If it's the fuser, which it will be, it'll probably be the thermistors.
                        • Lagonda
                          • Aug 2008
                          • 1649
                          Its the thermofuse/thermostat holders, the plastic goes porous after a while and starts to conduct when the humidity level rises i.e wet weather.
                          Played that game several times.,
                          • Llama God
                            • Mar 2009
                            • 1353
                            FUSER!!!
