All of the configuration has been set . ip, gateway, subnetetc . Drivers have been installed properly in pc . but no print and when I try to access web interface is says HTTP 403 forbidden access . website declined to show this web page . But I can scan to email . I am puzzled . Any ideas on this problem ?
Ricoh MPC 3500 no print and cant access web interface
Re: Ricoh MPC 3500 no print and cant access web interface
I've had this on a MP 5002, go into usertools, administration, and look under 'network security level'.
And move it down.
In my instance, I had the machine programmed proerply with netowrk settings but could not print, access the wim, or ping. I did the above and it allowed me to gain access.
John -
Just a few of the troubleshooting steps I can think of.“You pigs, you. You rut like pigs, is all. You got the most in you, and you use the least. You hear me, you? Got a million in you and spend pennies. Got a genius in you and think crazies. Got a heart in you and feel empties. All a you. Every you...'Comment
Check SP-5985, make sure it is set to 1.The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred HoyleComment
This issue is already discussed in detail go through it,
look
Choro1dal 's reply if this one helps,
First, you need activate telnet on the PC that you use to access to ricoh machine.
After, you start telnet with the comand in start menu, telnet IP, where IP is the IP machine.
you need loggin with admin and admin (admin, pass in blank in some models)
right there, you need to write the comand "access" and verify the access level configuration
with the comand "access flush" you reset the copier to initial values.
after you only need close sesion and save changes with "logout" command, say yes and now you can access to web image monitor.Comment
It is too late, a link to this exact solution was provided on page 1 of this thread.....nearly 4 years ago!Comment
RegardsComment
