mpc3500 doc feed problems
  • digicor
    • Jul 2008
    • 1159
    I have a mpc3500 that will just stop in stream when feeding, not crumple paper, just stops,seems like a dirty sensor,
    I have cleaned all the sensors that i can find, is there one some where else,?
    or do i need to "reset" the doc feeder's sensors?
    is the
    reset in section 6 adf ??
    or... is there a motor or clutch going bad?
    thanks
  • Colonel Bogey
    • Mar 2010
    • 19
    Clean the 3 black plates the sensors use as reference. They get coated in paper dust. 2 in recesses on top. 1 underneath on metal plate.
    • redneckstylin
      • Sep 2011
      • 173
      Re: mpc3500 doc feed problems
      clean the pucket on the flippy cover thingy make sure there is no dust in there...
      • Jomama46
        • 2900
        X2
        sigpic
        A+; Network +; PDI+
        • Jomama46
          • 2900
          Don't get technical with me sonny!
          sigpic
          A+; Network +; PDI+
          • MikeyP
            • Jul 2010
            • 18
            access sp mode input 5990 and get logging data.
            where are the jams indicated in the df section?
            presumably pick up roll, belt , sep roll and torque limiter have been replaced.
            • redneckstylin
              • Sep 2011
              • 173
              its humpday i feel non descriptive today just want friday to come
              • redneckstylin
                • Sep 2011
                • 173
                with everysale of a mpc 35/45 i include a bottle of canned air to compensate for ricohs great design
                • Llama God
                  • Mar 2009
                  • 1353
                  Check that the roller in the attached PDF isn't slipping intermittently on the shaft that it sits on.
                  MPc4500 ADF.pdf
                  • Masterchief
                    • Apr 2011
                    • 280
                    Had this problem numerous times TBH
                    replaced the friction pad, roller and the white roller (cannot think of its name duh) that connects to the roller as i can almost assure you that its cracked leading to slipping
                    Problem solved
                    Masterchief
                    sigpic
                    • kayjaig
                      • 144
                      I assume the roller # 22 ?
                      Please verify it?
                      • sandmanmac
                        • 3981
                        Originally posted by kayjaig
                        [ATTACH=CONFIG]17794[/ATTACH]
                        Please verify it?
                        Huh? No.
                        • CableGuy
                          Impulse Drive Engineer
                          • Oct 2008
                          • 417
                          If it's j53 in the logging data, then it's usually that sensor hidden behind the black on the under side of the adf....
                          But first port of call is to print the data, that'll pretty much lead you to it...
                          • kayjaig
                            • 144
                            Problem solved
                            Masterchief
                            What white roller that you indicate of? can you tell from the attachment photo ?ricoh adf.jpg
                            Thanks.
                            • mikadonovan
                              • May 2008
                              • 2931
                              What white roller that you indicate of? can you tell from the attachment photo ?[ATTACH=CONFIG]17806[/ATTACH]
                              Thanks.
                              I think he was referring to the torque limiter for the reverse roller, which I don't see in the diagram.
                              NEVER ASSUME ANYTHING
