MPC2500 Blurred image
  • johnny32
    • Oct 2007
    • 102
    Can anyonehelp with this prob.Blurred omage in the mornings for abbout 30 prints then works perfectly all day. Transfer cahnged aswell as the black drum as only happens on black. See attached
  • redneckstylin
    • Sep 2011
    • 173
    Re: MPC2500 Blurred image
    pcu or transfer grounding issue....
    • totoro
      • 568
      Is it only on black or on color copies also? Is the distance between the blurs the size of a drum?
      Totoro
      • Jomama46
        • 2900
        Sounds like a condensation problem, as the machine warms up, the moisture dissipates. Install drum heater kit. as was suggested measure the distance between the blurs to see if its a drum or xfer belt.
        sigpic
        A+; Network +; PDI+
        • redneckstylin
          • Sep 2011
          • 173
          the fella states that its only bnw so i would target blk pcu and or dv
          • Herrmann
            • Jan 2006
            • 792
            try to measure the gap between the distortions and divide it through , so you have the diameter of the potential sinner; in your case i would assume, that the black drum is the issue. maybe something is soiled and in contact with the drum while the mashine is standing over night, and the drum wiper has to do some work before getting it clean. And check the drum Gear and opposite too, maybe it is a drive problem.
            BTW.: you should black out personal data.... is it the real sinead o connor who needs healthcare?
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • Llama God
              • Mar 2009
              • 1353
              It's the drum, replace the PCU.
              You can measure the distance and divide it by pi (I haven't got the faintest idea where the symbol for that is on my keyboard, Herrmann's a genius!) but you'll find that it's the same as the circumference of the drum.
              It's the drum.
              • Llama God
                • Mar 2009
                • 1353
                Incidentally, pretty much every woman in Ireland is called Sinead O'Connor. All of the men are called Paddy O'Reilly.
                • nmfaxman
                  • 1705
                  Turn on fuser idle in service mode.
                  • Llama God
                    • Mar 2009
                    • 1353
                    It's the PCU, a common fault on the MPc6000s too in which the drums are supposed to do 450k. They never do, they smear like this.
                    The fault only occurs on mono too.
                    • Jomama46
                      • 2900
                      alt + 210 = ╥
                      also alt + 227 = π
                      sigpic
                      A+; Network +; PDI+
                      • Colonel Bogey
                        • Mar 2010
                        • 19
                        Check that the laser shutter assy isn't sticking . This can give the impression of blurring. If the firmware is old then loading the latest engine and system firmware will improve this function.
                        • Llama God
                          • Mar 2009
                          • 1353
                          Originally posted by Jomama46
                          alt + 210 = ╥
                          also alt + 227 = π
                          Hairy
                          By the way...
                          IT'S THE DRUM!
                          I'm just saying...
                          • bryand
                            • Jul 2008
                            • 92
                            wait..... maybe its the "rollers" lol
                            • Llama God
                              • Mar 2009
                              • 1353
                              You know though...
                              It's the drum!
