mpc3500 fax rexeption problems
  • mrfuser
    • 1604
    Client can receive from me and from another fax in house, but they can't from clients. Very sporadic. Is there a way to slow down modem and turn off error correction or something to fix this?
    Thanks all
    Kelly
  • Jomama46
    • 2900
    Re: mpc3500 fax rexeption problems
    Probably you should set up a triangular test circuit to see if its a particular telco station causing the problem.
    Aside from that: Comm sw 01 bit 0 to 0 will turn off ECM; G3 switch 06 bits3~0 set to 0011 will lower the Rx rate to 7200 bps
    sigpic
    A+; Network +; PDI+
    • SteveF
      Field Service Manager
      • Jul 2012
      • 49
      Hello
      Look up turning off ecm in the fax part of the service manual . It should help
      • sandmanmac
        • 3973
        Originally posted by SteveF
        Hello Look up turning off ecm in the fax part of the service manual . It should help
        Just to point out that Jomama gave precise instructions on how to do just that, in the only other reply. However, a little feedback as to whether it helped might prove helpful to the rest of us.
        • mrfuser
          • 1604
          I finally got back to client. Turned off ECM and slowed modem to 14.4 and it works perfect!
          Thanks all!
          Kelly
