Savin C4535 Scanner Setup Problem
  • markiemarky
    #16
    Re: Savin C4535 Scanner Setup Problem
    Originally posted by Llama God
    Really, the browser is naff, I never use it.
    If you have an XP PC, try scanning to that. If not, the next step is either a) a firmware update or b) a firewall such as Norton blocking it.
    In the case of a, you'll need to update the NIC firmware on the machine and this will have to be done by a Ricoh trained engineer.
    In the case of b, add a rule to allow traffic from the IP address of the copier and promote that rule to the top of the list.
    I know that this might seem silly, but create the folder in the root C drive on the PC and share that, giving you a path of \\pcname\foldername or, ideally, \\IPaddress\foldername. It could also be a DNS issue and using the IP address will rule this out or give you the answer to the problem.
    Unfortunately, we do not have an XP PC available. I will try to bring an old laptop tomorrow to test it out. I do not have an antivirus on the computer I am working on for it is a fresh install with only windows updates installed. I also have the windows firewall and UAC disabled.
    Also, the folder i created to share was in fact in the root folder but on drive D (second hard drive) for we have the drive C locked using DeepFreeze. I will try using the IPaddress\foldername and try again.. I'll post back in a few mins. If all else fails, this could really need a firmware update just like you mentioned.
    Once again, thank you so much for your help.
    EDIT:
    I tried what was mentioned above regarding the use of IPaddress instead of computer name but still no luck. I will try to use an XP laptop computer tomorrow and see if that will work. If all else fails, then I think the machine really needs a firmware update.
    I will heed your warning and I do understand the risk. I will notify our Administrator 1st before I proceed.
    Once more, thank you so much. I really do appreciate your help.
    • Llama God
      • Mar 2009
      • 1353
      #17
      Originally posted by ccchuah
      Try using ip address instead of computer name and upgrade the NIB firmware is the last solution.
      What he said / stole from me.
