Ricoh mp c6000
  • jtymabel
    • Aug 2008
    • 164
    [CQ] Ricoh mp c6000
    How do i enable duplex from bypass tray?
  • fbkhan3
    • May 2012
    • 421
    Re: Ricoh mp c6000
    It would be great to know duplex from bypass,as far as i know,no duplex from bypass,
    • jtymabel
      • Aug 2008
      • 164
      So you cannot duplex.from bypass tray. Need to run glossy paper duplex. Its 60lbs
      • mikedci
        • Jul 2010
        • 227
        • nmfaxman
          • 1705
          Re: Ricoh mp c6000
          Run second side through bypass.
          60 LBS won't work in duplexer , it will jam everytime.
          • jtymabel
            • Aug 2008
            • 164
            Well, i guess the specs for the copier are way off. Will have to duplex manually
            • mikedci
              • Jul 2010
              • 227
              Re: Ricoh mp c6000
              As for the specs it depends on what "type" of paper your glossy is counted at for weight
              60lb bond will jam every time...
              specs from the manual
              14 - 57 lb. Bond,
              20 - 80 lb. Cover
              29 - 119 lb. Index
              • jtymabel
                • Aug 2008
                • 164
                Whats the weight i can run duplexed
                • totoro
                  • 568
                  Totoro
