ricoh color copier
  • Polo-022
    • Sep 2007
    • 491
    #16
    Re: ricoh color copier
    How is the copy quality now ToM, do you have solid black on prints? Did you replace toner bank assy?
    Does specialist points to a worn/blocked black toner dispensing assy?
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      #17
      Originally posted by TonerMunkeh
      Yeah, tell me about it. I've had one kicking my arse for the last 3 days.
      I want more kudos for saying these are shit boxes and labour intensive in the rants rave section Which copier was the biggest piece of crap ever?
      oh and no we dont recommend these as copiers.
      Incontinentia Buttocks
      • TonerMunkeh
        Professional Moron
        • 3865
        #18
        I'm hoping a new set of bias rollers, bushings and an HV board will sort it. I've got a complete transfer assembly coming as well that I can pull parts off if required. I'll let you all know how I get on tomorrow.
        Hit it.
        • turbojetboy
          • Aug 2009
          • 279
          #19
          We had one of these doing a similar thing, 2 full k pcus where replaced in a matter of days, and in less than 1000 pages the black would start to fade away from the front to the rear of the sheet. the cq was spot on when the PCU and dev assy where replaced. We ended up fitting an entire new transfer assy (and new belt as the new transfer unit comes without a belt). Problem resolved. This machine had done around 600k black and 200 k colour.
          • bryand
            • Jul 2008
            • 92
            #20
            Im just waiting for Ricoh to re-introduce the 1224c as a new "retro" machine. Ahhh the failing dev units, huge PCU's, oil pumpin goodness : )
            • cleardata
              • Jul 2011
              • 137
              #21
              are you saying that ricoh 1224c is a durable machine? because i think i saw it in the Which copier was the biggest piece of crap ever? thread.
              • BLADE
                former propeller tester
                • 478
                #22
                Originally posted by FMC
                NEVER buy an Venus family machine MPC6000,6001. Awful, awful machine it's a very high maintenance bit of kit often sold to the wrong environment.
                usually if someone dont like a machine, someone else will defend them and say they are ok........lets wait
                • Scooper123
                  • Aug 2012
                  • 6
                  #23
                  no defense here the machines are terrible, toner spitting pieces of.....
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    #24
                    It is, without a doubt, the worst machine I have ever worked on. I cut my teeth on these things and can quite honestly say I have never met a machine that was such a god awful piece of shit.
                    Hit it.
                    • rapper
                      • 11
                      #25
                      unfortunately the whole group transfer belt.
                      Then look at the contact springs bias and pcu that are on the machine. I have found them bent and discharged to ground
                      • Llama God
                        • Mar 2009
                        • 1353
                        #26
                        Shite, if you do dev units and charge at 60k then PCU, fuser, feed, lens block assy and transfer clutch assy at 120k then these will run forever.
                        I'm trying to convince myself...
                        • cleardata
                          • Jul 2011
                          • 137
                          #27
                          thank you all for your comments. we will start with ricoh mpc4500's as recommended and stay away from those ricoh mpc6000's. your comments are very much appreciated and of big help. more power to you all.
                          • MFPTech
                            • 486
                            #28
                            For color quality I would recommend Canon or even KonicaMinolta, although KonicaMinolta machines are very high maintenance and not reliable.
                            I would definitely stay away from Ricoh and Kyocera color copiers, but I would consider Kyocera for Black and White.
                            • Nour mousawi
                              • Aug 2012
                              • 10
                              #29
                              Canon Color Copier IRC 6870
                              hi all...
                              im new here and in hurry i would like to ask about canon copier if somebody knows and can help...my copier is Canon Color Copier IRC 6870 , and my problem is that the LCD is blocked and i changed the screen but the block remained so how could i remove this block...thanck you all
                              • cleardata
                                • Jul 2011
                                • 137
                                #30
                                Re: Canon Color Copier IRC 6870
                                Originally posted by Nour mousawi
                                hi all...
                                i think it's best if you create a new thread under canon where most canon techs are there to help.
