Ricoh 1224c Print quality problems
  • philip byrne
    • Jul 2025
    [CQ] Ricoh 1224c Print quality problems
    Hey everyone,
    I recently started having problems with a Ricoh 1224c. A scanned test page is attached. I've tried changing al the toner cartridges, and I've tried a different PCU (not new but same results)
    Anyone have any idea what might be causing this?
    Thanks for any help, much appreciated.
    Philip
  • SteveF
    Field Service Manager
    • Jul 2012
    • 49
    Re: Ricoh 1224c Print quality problems
    hello
    you might want to try dev units to see if this has any impact on the c/q have known them run out of toner and not tell the m/c
    regards
    • Gift
      • Mar 2011
      • 2459
      Originally posted by SteveF
      hello you might want to try dev units to see if this has any impact on the c/q have known them run out of toner and not tell the m/c regards
      Nonono... better get a sledgehammer for this POS If you are odd enough to love this machine you can try: - a set of new Dev Units - dev drive assy - transfer cleaning clutch/drive assy I'd go with the sledgehammer.....
      • philip byrne
        hello
        regards
        Hi, I've already tried these from another photocopier too, is there anything else which you think might be wrong?
        Thanks, Philip
        • staffie man
          • Aug 2011
          • 59
          If not pcu or dev units,looks a lot like lens unit assy
          • staffie man
            • Aug 2011
            • 59
            As an afterthought did you change the charge corona unit
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • SteveF
                • Jul 2012
                • 49
                Hello
                i would try a new charge unit ..also a new transfer roller assy. make sure all the contacts are clean and make contact with the pcu and the contacts on the transfer roller
                hope this helps ...these m/c csn be a nightmare ...
                • Llama God
                  • Mar 2009
                  • 1353
                  Can you print out a colour test pattern from Printer SP and upload that?
                  I'd go with the charge wire and grid, mostly because they cost next to nothing, but it could also be the transfer drive assembly. I'll be able to tell better from the test pattern though.
                  I'm assuming that this scan is the print out rather than a copy?
