mpc4500 vs. mpc5000 adf swap?
  • mrfuser
    • 1622
    Does anyone know if the mpc4500 and mpc5000 use the same adf?
    Thanks all
    Kelly
  • Jomama46
    • 2900
    Re: mpc4500 vs. mpc5000 adf swap?
    Yep, both use the B802 (df3010)
    sigpic
    A+; Network +; PDI+
    • larryespinosa
      • Aug 2017
      • 10
      Anyone can help me find the part number for Ricoh MPC5000 ARDF DF3010 Document Feeder unit? Thank you
      • mrfuser
        • 1622
        You need an entire adf?
        • Lagonda
          • Aug 2008
          • 1649
          As far as I can remember the copiers came with the DF already installed so it couldn't be ordered as a separate item and never was available as a complete item ordered through the spare parts side of things.
          Anyway that model is now 5 generations old so the last one would have disappeared from the warehouse years ago.
          • ruben
            The New Guy
            • Oct 2012
            • 1204
            The EDP code is 413046.
            • larryespinosa
              • Aug 2017
              • 10
              Thank you so much Ruben! Appreciated. I am a newbie and a new Technician and it helps me a lot with this forum.
              • larryespinosa
                • Aug 2017
                • 10
                Yes the entire Document Feeder. Thank you
