Need a firmware for my Ricoh Africio 2018 to actvate the lan card
  • tetef
    • May 2012
    • 17
    Hi everybody,
    I need a firmware for my Ricoh Africio 2018 to actvate the lan card. If someone knows where i can it download, it will be great.
    thanks
  • sandmanmac
    • 3991
    Re: Need a firmware for my Ricoh Africio 2018 to actvate the lan card
    You don't need firmware, you need the "Print/Scanner" SD card for the slot, and possibly a memory Dimm, etc, that is required for TCP/IP printing. And before you ask, 'no' you can't simply copy the files from another card, or download it anywhere
    Edit....
    I just looked back at your posts, and it seems that back in May, you knew that it was an SD card you needed for this unit
    • tetef
      • May 2012
      • 17
      that's right,
      exact that what i need. But I couldn' find anywhere. Do you have any idea?
      Edit....
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Originally posted by tetef
        that's right,exact that what i need. But I couldn' find anywhere. Do you have any idea?
        An authorized dealer or eBay, take your pick. In any event, it's not free... but I think that's what you want.
        • nmfaxman
          • 1702
          Looking around your shop won't work if you don't have it.
          Search GOOGLE or any search engine.
          • tetef
            • May 2012
            • 17
            I will do it. Thanks
            • tetef
              • May 2012
              • 17
              I bought a Printer Scanner Unit Type 2018. I get on the both slots and each time i get a binary code on the LCD. What should i do? Do you have any idea? thanks
              • sandmanmac
                • 3991
                First of all. The SD card goes in the upper slot. Make sure it's unlocked. I also noticed that you're missing the USB board, and I wonder what else? Ram Dimm perhaps?
                After we check and fix all that. You may need firmware.
                You've been at this since May, and still haven't even bothered to get a manual.
                Good Luck.
                I'm tapping out!
                • Jude
                  • Oct 2009
                  • 256
                  WHy not buy the manual from Paul? His are genuine thing and not cheap imitations. Paul's copyright manuals are guaranteed free from defects and flaws for lifetime of the manual! He is really nice guy, but don't make him mad! justmanuals.com
                  • tetef
                    • May 2012
                    • 17
                    Hi sandmanmac,
                    thanks for your reply,
                    first i tried both slots, but i get the same error.
                    You are right. I am messing the USB board. This is a raison why i couldn't make an update.
                    You know, i was waiting all the time to get a Printer Scanner Unit from China. I talked to Ricoh support and he told me that i need only this card then will works.
                    Exactly. But i need first the USB Board.
                    Good Luck.
                    I'm tapping out!
                    • Jomama46
                      • 2900
                      From the looks of that display, I would say you have a loaded firmware card, not a print scan card.
                      sigpic
                      A+; Network +; PDI+
                      • tetef
                        • May 2012
                        • 17
                        Sur it is a printer scanner unit card. Because I am messing a USB card to update the firmware. Without the USB card I think I have no way to test my printer.
                        • femaster
                          • May 2011
                          • 1527
                          The Print/Scan kit also come with a stick of RAM (128MB) than must be installed onto the controller board. If you do not have this installed, it's not going to work, and is probably why you are getting the error.
                          G3315720 - PCB SDRAM-DIMM 128mb Ass'y
                          Not sure what the pin-count is on that, but I'd recommend buying the right type and size of RAM from anywhere BUT Ricoh. They will rape your butt hole with how much they will charge for it, when you could probably buy it somewhere else for under $20.
                          • tetef
                            • May 2012
                            • 17
                            Originally posted by femaster
                            The Print/Scan kit also come with a stick of RAM (128MB) than must be installed onto the controller board. If you do not have this installed, it's not going to work, and is probably why you are getting the error. G3315720 - PCB SDRAM-DIMM 128mb Ass'y Not sure what the pin-count is on that, but I'd recommend buying the right type and size of RAM from anywhere BUT Ricoh. They will rape your butt hole with how much they will charge for it, when you could probably buy it somewhere else for under $20.
                            thanks femaster, I want show you my board. But I am not sure nether where the G3315720 will be placed nor where i could buy it with 20$. Do you have any idea? Thanks
                            • Bantams
                              • Jun 2012
                              • 603
                              If your controller dosnt have the dimm socket B then you will Never be able to get that machine to print without getting the controller option with the dimm socket.
