MPC-7500
  • T911
    • Jun 2007
    • 628
    MPC-7500
    This one has me for a loop. I can't watch and see what is going on. I looked into the pc units and transfer area to see visually if anything is out of wack but all looks good. Machine has 270k bw and 154k color on it. i don't see a staull and don't here any noises for brocken gears. image as you can see is there but just blurred. view attached file. thanks
  • Bantams
    • Jun 2012
    • 603
    Re: MPC-7500
    Funny enough I had this same issue 2 days ago after the Customer had left the front door open and Light had got onto the Black Drum.
    After doing a few Hundred Copies it went back to Normal Try Individual Col copies ie do a copy in cyan yellow and Magenta and then do one on black only and i bet the single col copies are not blurred and the Blk one is.
    • tjvincent
      • 280
      Re: MPC-7500
      That looks like humidity, did you run a bunch of copies ? Try single color cyan, mag, yellow. I have seen that in small offices after a weekend, it goes away after it is run a bit.
      • Llama God
        • Mar 2009
        • 1353
        Re: MPC-7500
        Are the PMs all up-to-date?
        • BLADE
          former propeller tester
          • 478
          Re: MPC-7500
          looks normal to me
          • fbkhan3
            • May 2012
            • 421
            Re: MPC-7500
            Looks like, Time to rebuild the black PCU!lubricant bars,Springs,
            (MPC 7500)these beasts are known for CQ issues,PM Unit's always way less then 450K,
            • turbojetboy
              • Aug 2009
              • 279
              Re: MPC-7500
              Thats the answer, and you should replace the black coro unit - as it is my experience that changing this along with cleaning or replacing all the air filters will go a long way towards stopping the exact problem of blurring your sample shows.
              • Masterchief
                • Apr 2011
                • 280
                Re: MPC-7500
                I agree with this post, i also had this problem solved by doing this procedure
                Masterchief
                sigpic
                • BLADE
                  • 478
                  Re: MPC-7500
                  This thread is quite remarkable and unlocks some of the issues with this model. I,ve seen the condition on the sample also after having the pcu out for a few minutes during a call. Wasnt sure what was going on but the copies came good after about 200 copies.
                  I think that indicates the drums are over sensitive to light.
                  Are there any old Canon techs here from the NP4835 analog series? Those machines were released with a drum that 'went off' when exposed to outside light (faded patches). But more importantly they suffered 'light fatigue' during normal use from the exposure lamp and that model had a new invention which was a laser to do the lead edge blanking. The drums fell way short of their target. A few months later new drums were issued and the machines ran good.
                  I reckon the same thing is happenning with this model. The process control aint happy and amps everything up trying to get solids up, so you end up with overtoning, all because of a weak drum. 2 cents worth.
                  • Llama God
                    • Mar 2009
                    • 1353
                    Re: MPC-7500
                    So, are the PMs up-to-date?
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Re: MPC-7500
                      Just to throw another possible cause into the mix.... Strip the transfer unit out and look at the bushings that sit either side of the bias roller for black. You might find the front one has worn on it's inner surface causing the bias roller to stall. I've had that cause this issue before and that image defect does look rotational.
                      Hit it.
                      • BLADE
                        • 478
                        Re: MPC-7500
                        what was the meter count for this fault, the posters m/c is fairly low miles - cheers
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          Re: MPC-7500
                          300k black, 1.91 million colour. Guess what sort of environment this piece of shit got sold into!
                          Hit it.
                          • Horologydoc
                            • Jun 2011
                            • 61
                            Re: MPC-7500
                            I've had dirty MUSIC sensors cause a similar effect to this in the past.
                            • BLADE
                              • 478
                              Re: MPC-7500
                              it will either be a print business or a rundown church
