toner out error
  • Eydgbert
    [Misc] toner out error
    I have a ricoh c4500 with a toner out error even when then is a new toner bottle put in machine, the black toner bottle only
  • engineers
    • 51
    Re: toner out error
    Most Likely be the Black toner pump has had it, when you replace it make sure to replace/hoover out the pipe also
    • fbkhan3
      • May 2012
      • 421
      Re: toner out error
      http://www.copytechnet.com/forums/ri...ner-black.html
      This will be helpful,
      Toner pumps often fails in these models but not very often when use OEM or Genuine Ricoh Toners,also sticking clutch could be the reason!
      good luck!
