MP 3350 Fax notification to email
  • john_551
    • May 2009
    • 23
    [Misc] MP 3350 Fax notification to email
    Hello,
    I can't seem to find out any information on email when a fax arrives.
    I have a MP 3350 set up with fax forwarding to folder, I was just wondering is there a way to send an email to an address when a fax arrives?
    I'm finding that customers are not checking the folder to see when faxes arrive.
    Or is this even possible?
    John
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: MP 3350 Fax notification to email
    maybe fax reference manual can help you, read the reception and transmission section.
    Nobody is perfect..
    • sandmanmac
      • 3981
      Why not just have the faxes forwarded to a common email account rather than a folder?
      • john_551
        • May 2009
        • 23
        Ok, decided to take advice and have faxes sent to email.
        Now the big problem I have is all the faxes are tif, how do I change the forwared faxes from tif to pdf?
        Is there an sp I'm missing?
        Any help would be greatly appreciated.
        John
        • sandmanmac
          • 3981
          John
          User parameter switch: 21, Bit: 3
          0: Tiff
          1:PDF
          • john_551
            • May 2009
            • 23
            0: Tiff
            1:PDF
            Hi,
            I've already done that above, that is what I use for forwarding the fax to a folder.
            But when I forward the fax to email still tiff, I was just wondering what setting am I missing.
            John
            • sandmanmac
              • 3981
              Hi,
              John
              The setting only applies to Fax to email. Forwarding to Folder is only available as Tiff (as far as I know). Double check you've set the correct parameter to "1". It is the correct one
              • john_551
                • May 2009
                • 23
                I know what you are saying, but that switch is only for forward fax to folder and 1 is pdf (switch 21, bit 3).
                I'm starting to think that the machine does not support fax forward to email in pdf. I've set up multiple machines in the past with forwarding to fodler in pdf, but not to email.
                I've been on the tsrc and I have to admit ricoh is not of much help. I'll have to look at the matrix again.
                John
                • john_551
                  • May 2009
                  • 23
                  As it just happens, the machine does not support forwarding the faxes in pdf to email, only tiff.
                  So I just decided to leave it on fax to folder in pdf and have a program send an email from the server.
                  John
                  • sandmanmac
                    • 3981
                    John
                    Yes it does. Unless it's a 'B' version (which might not support it). I set up an 'SP' version just a couple weeks ago with forward to email in pdf
                    • mikedci
                      • Jul 2010
                      • 227
                      fwiw D019( b version) is on the supported list as well...
                      • jtyler
                        If you have a Model that only has 3 tabs (Folder-Internet Fax- Fax) for the receiver when you are setting the forward destination you will not be able to scan to e-mail as PDF. If you ae choosing Internet fax as the receiver then it will only transfer as a Tiff. If you have 4 tabs you must select E-mail and set user switch parameter 21 bit 3 to 1.
                        • Black Cloud
                          • 161
                          I found this link to a free third party product that will pop up whenever a shared folder is accessed. I've never tried it, but it may be worth a shot. https://www.sugarsync.com/products/sync_sharing.html
                          Net+ PDI+ @Remote
