Re: Odd MP 2550 Fax Issue
Do you have access to the 2045? if so, i would try to save, note, printout, whatever... all of the settings and try to migrate them to the new mashine.
BTW.: You never ment getting an error code, make an sp print and print out all logs and check for error codes, then post them here.
BTW2.: i would try to set the ncu parameters to malaysia or south africa
And they never had a problem with the previous Ricoh 2045 receiving from this customer.
