Setting up a Ricoh Mp 2500 on a workgroup not a domain on Xp
  • lopez1870
    • Jun 2025
    Hi guys i have a problem setting up a Ricoh thru a workgroup .
    I can print on it no problem but scanning its a other story here is what its doing.
    When I open the web monitor and the address book i have selected smb i have put the user name and password of the main computer and the path of the forder i what to scan but when i scan on it it said unable to connect check network settings so i did all the ip address is correct any idea?
    I really need help thanks guys....
  • digicor
    • Jul 2008
    • 1153
    Re: Setting up a Ricoh Mp 2500 on a workgroup not a domain on Xp
    If its win 7 this works every time
    Here is something I found on another site that got SMB scanning to work on windows 7 pro, pc. It is a registry change if you have the gusto.
    Copy and paste this into a new notepad document:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\LanmanServer\Parameters]
    "SMB2"=dword:00000000
    "SMB3"=dword:00000000
    save as smboff.reg.
    Run smboff.reg.
    This disables SMB 2 & 3. Give it a try and let me know your success.
    • lopez1870
      Thanks for the reply.
      I am sorry if I didnt clear on my post i am using windows xp i dont have windows 7...
      save as smboff.reg.
      Run smboff.reg.
      • ccchuah
        • Mar 2009
        • 153
        The computer must be on the same network and the share folder must have read and write permission for anyone.
        • nmfaxman
          • 1702
          Post the NIB summary from the machine so we can see what all the settings are.
          User tools/ interface settings/ Print list.
          Scan it from another working machine and attach the file to your post.
          You can black out serial number before you scan to protect info.
