blurry image
  • thecopyroom
    • 10
    [CQ] blurry image
    I'm getting a blurr in the cross feed direction (front to back) in black only, it is about a 1 inch and varies to about a mm, after a while of making copies it goes away. when copies are done and sits for a while it does the same all over again. help if you can!!
  • Masterchief
    • Apr 2011
    • 280
    Re: blurry image
    Sorry but could you post the model of machine and life count please, The information above is very limited to provide any help with this matter
    sigpic
    • thecopyroom
      • 10
      Re: blurry image / Ricoh mpc6000
      The post above is for a RICOH MPC6000
      • thecopyroom
        • 10
        Meter 22,000 color / 296,000 K
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: blurry image
          Sounds like the black PCU is ready for a good strip and vac out. Has this thing ever had a good strip down and clean? If not, it is well due for one. Pay particular attention to the lube bar in the black PCU as well, that could be on it's way out.
          I assume this machine doesn't get much use seeing as it's only done 330k-ish total?
          Hit it.
          • thecopyroom
            • 10
            I'm a small printer and i have read all of you're treads about the mpc6000 and most of you guys don't talk well about this ricoh.
            I just got the machine to replace two old canon c3200 that never ran right. we will do as you asked and update you later.
            • cva
              • Jul 2012
              • 23
              Re: blurry image
              bro as i know irc3200 is a worse colur machine, ricoh mpc colour mc is better than that, as i know use genuie parts to repace. .its sure will have good perform.
              • TonerMunkeh
                Professional Moron
                • 3865
                Don't try and service one of these things yourself, whatever you do! Get a tech out and make sure he fits OEM parts and knows the machine, otherwise it'll severely bite you. Make sure you use OEM toner too.
                Hit it.
                • Tonerbomb
                  AutoMajical Resolutionist
                  • Feb 2005
                  • 2589
                  X2 ! a good tech can make these run well, a sloppy tech... well you'll get what you pay for.
                  Mystic Crystal Revelations
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Re: blurry image
                    Paul@justmanuals.com
                    • thecopyroom
                      • 10
                      TONERMUNKEH, My tech did as you instructed. Now it prints great. Any info on keeping it up the c6000 will be greatly appreciated.
                      Lee / The Copy Room
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        Lee / The Copy Room
                        We service the PCU's, including developer, every 500k. On black PCU service I replace the fuser oil supply roller and cleaning roller. ITB and PTR blades / lube bars run from 500k to 750k depending on the work they have to do. Tell your tech to keep an eye on the drive gears on the back of the fuser, there is a plastic gear that can get shredded causing fuser jams.
                        The most important things to do with these machines is every 250k or so, vac the living death out of them. Make sure parts are replaced as and when the machine needs them, don't skinflint as these things will quickly turn into an ocean-going nightmare.
                        Hit it.
