RICOH mp 6002 SP, mp 7502 SP Doc Feeder Jamming
  • KCAGLE
    • Aug 2025
    [Jamming] RICOH mp 6002 SP, mp 7502 SP Doc Feeder Jamming
    we have installed three brand new units and all three are having intermittent Jamming in the doc feeder. Anyone else seen this problem and if so what was the solution?
    Kevin
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: RICOH mp 6002 SP, mp 7502 SP Doc Feeder Jamming
    What jam locations are they giving?
    Hit it.
    • KCAGLE
      All three have been jamming at the registration sensor in the DF. We are trying buckle adjustments, but without any success. We've checked the one way bearings, but all seem to be ok. Sensors are clean (machines in place less than a week)
      • kyrenecopy
        • Apr 2012
        • 205
        To repeat TonerMunkeh's post: What error/jam codes are you getting. They will tell you where the problem is occuring and/or what sensor/switch is causing the problem. It is not perfect but it will help
        Testing 1-2-3, testing, testing. Is this thing on?
        • KCAGLE
          Jam code 006 which refers to the paper reg sensor which we have tried to fix by replacing it. But continues to give the same code
          • Eric1968
            • 2458
            The same problem for 3 machines? Are the document feeders properly mounted on the machines?
            • Bantams
              • Jun 2012
              • 603
              Check for a Firmware update unusual to have the same problem on 3 machines its usually the firmware
              • kyrenecopy
                • Apr 2012
                • 205
                ADF MECHANICAL FAILURE No drive from transport rollers. Follow procedure outlined in TSB # 030.
                ADF MECHANICAL FAILURE No transport roller drive - refer to TSB # 030.
                ADF NOT RECOGNIZED Dead DF - Internal short in CIS damages DF main - DF not recognized
                ADF NOT RECOGNIZED Firmware was updated on a non-updatable ADF Main board, replace ADF main board.
                ADF RUNS SLOW Check for pinched harness on adf lift table sensor
                ADF RUNS SLOW Check or replace adf main pcb
                ADF RUNS SLOW Check communication cable between ADF and copier
                DF EXIT JAMS J005/J006 refer to BULLETIN NUMBER: D062/D063/D065/D066 ? 030
                DF EXIT JAMS refer to TSB #030
                DF FEED IN JAMS ADF feed in jams. Check or replace feed in plastic covers on ADF.
                DF FEED IN JAMS ADF feed in jams. Suggest to replace feed in platic covers on docuemnt feeder.
                DF FEED IN JAMS Jam code 003 (skew correction sensor on check) - Replace one-way gears
                DF FEED IN JAMS Jam code 003 (skew correction sensor on check) - Replace pickup, feed belt and sep roller
                DF FEED IN JAMS Jam code 006 (registration sensor on) - Clean and lubricate idle pulleys for transport and scanner roller drive belts
                DF FEED IN JAMS Jam code 006 (registration sensor on) - Loosen transport belt tension 1~2mm
                DF JAMS Refer to TSB D062-003 for location of one way bearings to be replaced
                DF JAMS Software error - After an ADF Jam and reloading originals - Update System Firmware to Custom LRC0360 (RFG051657)
                JAM CODE 006 4th paper feed sensor: late - sensor defective (japan only)
                • pocket aces
                  Ricoh Technician
                  • Nov 2008
                  • 72
                  rfg050724.pdf I know its a 6002 but check this tsb out anyway I had this 06 jam and this worked
                  • margic brian
                    • Jul 2012
                    • 97
                    Kevin
                    hope you fixed the scanner glasses well for each of the mach
                    ines
                    • tcs04
                      FORMER Techie
                      • 1183
                      ines
                      Do they work in free run?
                      Sounds enviromental (Poor originals) or firmware. The chances of all machines having the same problem are very slim.
                      • KCAGLE
                        Glasses? Not sure if your making a joke I didn't quite get or if I just don't understand the question. If serious please explain? Not sure what you mean.
                        • KCAGLE
                          Replacing 6001's with 6002's. the originals were not an issue with the previous version.
                          • Imprestik
                            • Aug 2012
                            • 297
                            Check the idle gear on the feed belt drive shaft. The one which the feed belt shaft docks into. I have found on a number of new devices that the idle gear which is supposed to be stuck in position is actually not, and slips intermittenly causing a jam. It all comes as 1 piece in the service manual with the one way bearing on the front, and the idle gear pressed onto the shaft. You will need to remove it and turn it by hand, only way you can tell if it's stuffed or not
