Ricoh MPC6000 animation, can not enter the operating system. Is this what is the reason?ing running machine.
Re: Ricoh MPC6000 animation, can not enter the operating system. Is this what is the
do you mean its stuck on boot up sequence? if so try to access the sp mode and format the the imh on the hdd or disconnect the hdd to see if it will boot up. -
I hate guessing which part is bad. Think out of the box?
1. Pulled those hdd out and format it in your computer.
2. Download Smart Device Monitor software from http://support.ricoh.com/bb/pub_e/dr.../z52276L10.exe. Start the software on your laptop while the machine is connected with the network cable.
If you're unable to WIM into the machine then replace the controller board.
Keep us posted if it wasn't the controller.Comment
