Change Default on Duplex for Ricoh Aficio MP7500
  • powshar
    • Jun 2011
    • 52
    [Misc] Change Default on Duplex for Ricoh Aficio MP7500
    Hey- We have a Ricoh Aficio MP7500 that defaults to double sided copies. We need to change this to single sided copies. We have the Service Manual for it , but have had no luck. Can you help? Is this strictly a User function?
    Thanking you in advance.
  • johnyb
    • Feb 2011
    • 167
    Re: Change Default on Duplex for Ricoh Aficio MP7500
    Hi
    1. Go to the copy screen, deselect duplex.
    2. Then go to the Program key (looks like a diamond).
    3. Then Program.
    4. Program as defaults.
    5. Confirm.
    Thats it!
    • powshar
      • Jun 2011
      • 52
      Originally posted by johnyb
      Hi
      3. Then Program.
      5. Confirm.
      Thats it!
      Is this in User Modes or in SP Programs?
      • sandmanmac
        • 3990
        You are over complicating your problem.
        Just do as Johnyb says...no special "modes" .
        Look at the (regular) copy screen, de-select duplex ....an so on, as he suggested
        • powshar
          • Jun 2011
          • 52
          Thanks! I appreciate your help.
          • sandmanmac
            • 3990
            You`re welcome. However, it never hurts to check the Ricoh `knowledge base` for day to day issues like this:
            Ricoh USA - Support Center
            How to turn Duplex as Default to Off in Copy Mode
            Print Email this page
            Published 04/05/2007 04:51 PM | Updated 04/10/2007 11:38 AM | Answer ID 62791
            How do I turn Duplex as Default to Off in Copy Mode?
            1. Select [Dup./Combine/Series] on the display panel.
            2. Press [Cancel] to clear duplex settings.
            Note: The other default settings you can program are: Color Mode, Paper Tray, Original Type, Special Original, Original Orientation, Cover / Slip Sheet, Edit / Color, Reduce / Enlarge and Finishing.
            3. Press the [Program] key on the operation panel.
            4. Press [Program as Defaults]
            5. Press [Program]
            6. Press [Yes]
            7. Press [Simplified Display] key and repeat steps 1 - 6 if you want the Simplified Display Mode to have the same defaults.
            • Oze
              Ricoh Fanboy
              • 1663
              Good job guys...you can't make it any simpler than that
