Mpc 3000 Skewed image
  • johnny32
    • Oct 2007
    • 102
    Wondering if anyone has come across this problem. When copying from glass and the Adf i am getting a skewed image on the copy. Have checked reg roller clutch etc. Have checked the mirrors postions by lining them up with the locator points in the scanner. The problem is occuring in all drawers including the system stand and bypass tray. Have checked the printing and that is all fine so appears to me to be an optical issue but not sure as to what. Please see attached for an example of a copy a smc print out.
  • JustManuals
    • Jan 2006
    • 9865
    Re: Mpc 3000 Skewed image
    Paul@justmanuals.com
    • tcs04
      FORMER Techie
      • 1183
      I recently saw something similar on an MPC4500, but mine was on prints as well!
      Yours looks like scanner... Have you set the scanner with pins as per the manual? (Phillips #2 screwdrivers work well)
      Print a trimming pattern in black to confirm the issue is ONLY when copying.
      I assume the print of the SMC you posted was copied "Long Edge First"?
      Do the "Straight" sides have any curve? (if yes, reg roller?)
      If you put A4R in tray 2 and select auto reduce enlarge, does the skewed edge change to the short side?
      If no, probably optics, if yes, its the engine.
      • Polarbear
        • Feb 2012
        • 1070
        @tcs04: "Have checked the mirrors positions by lining them up with the locator points in the scanner."
        If you say printing is fine, it has to be optical! And it will then also happen out of all trays.
        Are you sure the scanner assembly is straight? I see you did the alignment, but I mean the scanner frame itself. If you remove the left slit glass cover and lightly tap on the main copy glass it shouldn't sound "lose", as if it is not sitting flush on all sides of the scanner frame. If it does sound lose, then the scanner frame is bent, and needs to be straitened, but lifting the left front edge of the frame upwards.
        Also check that the adf is sitting straight on the scanner assembly, as these bend as well. The right side edge of the adf should line up perfectly with the right side of the scanner frame.
        Are the mirrors sitting flush in their holders? Lightly press on each one's corner and check that they are all in position on the holders.
        Press the GREEN button!!
        • Herrmann
          • Jan 2006
          • 792
          What happens, if you apply some force to the front left edge of the scanner house? Try pushing and pulling with moderate force, what happens?
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
