Just a quick question here, not sure if anybody else has seen this...
Was setting up a new MP4002, right out of box. Doing all the usual configuration, but when it came to turning on the "Data Overwrite Security" (User Tools, System Settings, Admin Tools, Auto Erase Memory Setting), I got a dialog box that indicated I did not have permission to change this setting. There was another setting (that I forget now) as well that was locked like this, so it effects more than just this, but I figure if I can get the one solved, it will clear up the rest.
According to the service manual, there is no special login to receive permission to change this, just go to the setting, turn it on, and choose the level of security.
I've checked both the Administrator Authentication and User Authentication, everything is turned off in both. Pressing the login button on the control panel results in an error (double) beep, no matter what screen I am on, so there is apparently nothing to log into. There is no on-screen login button under the initial User Tools screen.
Any ideas on this one?
