ricoh aficio 220
  • copicatt
    • Nov 2008
    • 366
    ricoh aficio 220
    I do not normally service Ricoh, but this one is leaving a 2 inch wide blank area (lead to trail) bout halfway down the page.tick marks on the edge of the blank areas. Does it bout 80% of the time. NOTE: if i reduce to 50%, the blank area reduces along with the image, so it is an optical problem. Anyone seen this? I will try to upload a sample tomorrow....
  • teebee1234
    • 1670
    Sounds like you might have light leaking in from the white pad on the lid. The edge can deform (usually ripple), letting in light (the tic marks would be from the 60 hz fluorescent lamps on the ceiling, they're flickering 60 times a second and the scanner is picking it up). Turn the lights off in the room and make a copy to confirm.
    • savi0r
      • Sep 2010
      • 363
      Re: ricoh aficio 220
      Since there's this thread open.... I have a quick question. How do you set up the A3 format for the second tray? Is it from those 4 switches from the tray? I read about them in the manual but just want to get sure. And another thing : if the machine displays " replace photoconductor unit" does it stil copy/prints?
      • TonerMunkeh
        Professional Moron
        • 3865
        It's been that long since I've seen a Russian C1 I can't remember if they have the green wheel on the front right hand side of the tray to select the paper size. If it does, that's how you do it. Failing that, it'll be in user tools.
        With regard to the photoconductor unit message, it will continue to print and copy with this message showing but replace the PCU anyway. With a machine this old it'll thank you in the long run for replacing it's parts on time.
        Hit it.
        • Polarbear
          • Feb 2012
          • 1070
          I agree with TonerMunkeh on the dail setting. It sits on the front right of the tray. Make sure that it is set correctly, and then check what it shows on the display, as sometimes those switches are troublesome...
          Press the GREEN button!!
          • savi0r
            • Sep 2010
            • 363
            In my area (btw, i'm from Romania) some firm sells these machines and claims they are top notch. They try to pass them as some kind of new and reliable machines. What's your opinion on these machines? Any pro/cons? Just curious.
            • Bantams
              • Jun 2012
              • 603
              They are better than most of the new stuff and very reliable if you replace the PCUs every 80k (Works ok for us) and check the fuser bearings and rollers every visit.
              • sandmanmac
                • 3964
                Pros: Great machine
                Cons: Over 12 years old, and getting difficult to get parts other than consumables
                • Dumus
                  • Feb 2010
                  • 79
                  Clean shild glass (left under the toner bottle). If that does not work, then you have pull out polygon motor, and clean up the edges on it.
                  Good Luck.
                  I love it
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    The original Russains are bomb proof, one of the best machines Ricoh ever put out. As Bantams said, keep an eye on the PM parts and lower fuser frame, clean the ID sensor, PCU cavity and pressure roller cleaning roller every call and they'll pretty much look after themselves.
                    Hit it.
                    • teebee1234
                      • 1670
                      Good Luck.
                      I love it
                      The original posts states that the blank area reduces with the image when he sets it to 50%, so it can't be the shield glass or the mirror motor. I stand by my response as I've seen this problem in the past.
                      • savi0r
                        • Sep 2010
                        • 363
                        I do not know this machine very well, but as teebee said, the problem can't come from the shield glass or the plyogonal motor. When faces of the polygonal motor are dirty, it causes fainted image on the copy, but you can still distinguish something in the fainted area. It doesn't leave blank spots or bands.
                        • JustManuals
                          • Jan 2006
                          • 9838
                          This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment
                          from Just Manuals, The Internet's largest selection of manuals ~ Instant Downloads
                          Paul@justmanuals.com
                          • cleardata
                            • Jul 2011
                            • 137
                            any help also with my clients aficio 270, still can't access the sp mode no matter how i press the yellow 107 orange buttons. it's been on standby for quite some time already. all buttons are working when i checked.
