mpc 3500 sc 362
  • mrgene
    • 53
    mpc 3500 sc 362
    I know the code says hard drive detection error 2
    We replaced the print controller. Is there another harddrive on the copier?
    help please
  • femaster
    • May 2011
    • 1504
    Re: mpc 3500 sc 362
    help please
    Hopefully you miss-typed the SC code, as a SC362 has nothing to do with the hard drive. There is a problem with the Cyan TD Sensor...
    SC362 -- TD sensor (Vt high) error 1: C
    • The Vt value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 4.7V) with SP3020-002 for twenty counts.
    • The [Vt - Vtref] value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 5.0V) with SP3020-001.
    • Black, magenta, cyan, or yellow TD sensor disconnected
    • Harness between TD sensor and PCU defective
    • Defective TD sensor.
    1. Check the black, magenta, cyan, or yellow TD sensor connector and harness between the TD sensor and PCU for damage.
    2. Check the drawer connector.
    3. Replace the defective PCU.
    • sandmanmac
      • 3981
      Re: mpc 3500 sc 362
      Yup....Either referencing the wrong manual for this SC code (aficio 2022) or mistyped it. But I don't believe there's an HDD detection error code on C3500
      That sure makes giving advice a bit more tricky
      • femaster
        • May 2011
        • 1504
        Re: mpc 3500 sc 362
        There are a couple of things for the HDD, but even if it were a miss-type, there is no SC862 listed in the manual either...
        The only things I can see would be:
        822 - Self-diagnostic error: HDD (Hard Disk Drive)
        860 - HDD: Initialization error
        861 - HDD: Reboot error
        863 - HDD: Read error
        864 - HDD: CRC error
        865 - HDD: Access error
        There are a few other ones for the HDD, but nothing that I think would be significant.
