MPC2500
  • GeorgeBest
    • Jul 2009
    • 526
    MPC2500
    Got a MPC2500 with a SC551 error.
    I've changed the thermistors, I know I have to reset
    this but I can't enter the simulation, it just beeps when
    the code is put in . . .
    What am I doing wrong here ?
    anyone, thanks in advance
  • dewaldvdp
    Re: MPC2500
    You press
    Yellow cancel
    107
    Hold red cancel
    Service Mode wil come up.
    Select Service SP
    On the number pad en 5810 and press #
    It should take you to the Reset SC option.
    Press execute then okay
    Restart the machine
    • thierry
      • Apr 2012
      • 30
      Re: MPC2500
      Hi George.
      I had similar problem and found the thermopile was blown. Replaced with new one and solved the problem.
      Hope it helps.
      • Zeldaman
        • Mar 2011
        • 946
        Re: MPC2500
        Hi there!
        Is it possible, that there are some printjobs on the machine? If so, you had to delete them, otherwise no enter to the techrep-programm.
        Greetings...
        • GeorgeBest
          • Jul 2009
          • 526
          Re: MPC2500
          That is the problem,
          I did Yelow, 107, red (hold) but is won't work, just the beep ?
          Originally posted by dewaldvdp
          You press
          Yellow cancel
          107
          Hold red cancel
          Select Service SP
          Restart the machine
          • dewaldvdp
            Re: MPC2500
            If it doesn't go into SP mode then your HDD probably crashed. You can remove it and format it using an external bay or by plugging it into a computer and formatting it there. Remember to format the HDD as a NTFS.
            • GeorgeBest
              • Jul 2009
              • 526
              Re: MPC2500
              Oke, but how can I delete the printjobs ?
              the machine is in SC551 and I can not go into the printmode
              Originally posted by Zeldaman
              Hi there!
              Greetings...
              • Bantams
                • Jun 2012
                • 603
                Re: MPC2500
                Try pressing the Loggin button and then entering sp mode from the loggin window loggin button being the one below the power button.
                • ucinn
                  • Jun 2009
                  • 383
                  Re: MPC2500
                  Just shut the machine off, disconnect the ethernet and phone cables, then turn it back on and go into the service mode to reset.
                  • margic brian
                    • Jul 2012
                    • 97
                    Re: MPC2500
                    love your comment thats the right answer
