Riicoh 2232c Streak on Back of page
  • mrfuser
    • 1622
    We have a persistant streak on running down the page on the back of any copy. We changed fuser, black drum, entire transfer belt assembly. Still get the streak. It is about 3/4 inch wide on back. Front of copy looks great.
    Any thoughts?
    Kelly
  • teebee1234
    • Jul 2008
    • 1670
    Did you replace the transfer belt cleaning blade too? If not, that should be your next step. If you pull out the blade assy you will probably see a toner buildup on the blade that corresponds to the streak location. Also look at the pressure bar that pushes against the belt, you will also see a ring of toner around it.
    • sandmanmac
      • 3983
      Re: Riicoh 2232c Streak on Back of page
      x 2 on the blade
      • mrfuser
        • 1622
        Turned out to be a new defective transfer blade.
        Kelly
