MP201SPF
  • tludden
    • Oct 2011
    • 7
    MP201SPF
    Hey guys,
    anyone of you encounter when fax forwarding to email suppose to be in PDF format but still received in tiff format?
    parameter setting for switch 21 bit 3 already set to 1.
    any other setting that need to be changed???
    Or is it not possible to forward to email in PDF?
    Looks like switch 21 bit 3 is for folder forwarding.
    Any help would be great.
  • mikedci
    • Jul 2010
    • 227
    Re: MP201SPF
    MACHINES NOT SUPPORTING FAX FORWARDING TO EMAIL AS A PDF:
    Below is a list of machines that do notsupport Fax Forwarding to Email as a PDF:
    Product
    Code
    D116
    D115
    MP 201F
    MP 201SPF
    N/A
    LD 220F
    LD 220SPF
    920F
    920SPF
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Re: MP201SPF
      Just because the switch is there doesn't mean it will work.
      Mikedci is right.
      Just as a heads up: Make sure your sales force knows this. I've had more than a few of them get into deep doo doo because they didn't know this.
      Although it looks like it may be a tad too late...
      • tludden
        • Oct 2011
        • 7
        Re: MP201SPF
        It also appears that the New MP301spf is the same no e-mail pdf.
        It looks like the MP2352SP will support it. Switch 45 pdf is default.
        • Black Cloud
          • 162
          Re: MP201SPF
          I would try updating firmware. I had a different model with the same issue. Firmware solved it.
          Net+ PDI+ @Remote
          • PinevskiS
            • Jul 2009
            • 283
            Re: MP201SPF
            Originally posted by tludden
            Hey guys,
            This small machines not support fax forwarding to email to be in PFD ,only TIFF.
            • PinevskiS
              • Jul 2009
              • 283
              Re: MP201SPF
              Only fax forwarding on FOLDER can to be in PDF.
              • tludden
                • Oct 2011
                • 7
                Re: MP201SPF
                See attachment.
