MP161 Fax question
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    MP161 Fax question
    I have a client with a 161 and they really like the machine.
    the only issue they have with it is the memory transmit for faxing out.
    Is there a way to turn off the memory transmit and have the default to immediate ?
    I have been all through the service and user manuals and am unable to locate how to
    disable this function.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
  • sandmanmac
    • 3981
    Re: MP161 Fax question
    Switch 2, bit 1 on the 'home position' switches:
    user tools/fax features/administrator tools/parameter setting/home position
    Home Position Parameter List Do not change switches other than those listed.
    00 3, 2, 1 Image density 000: Normal density
    001: The lightest density
    010: The darkest density
    101: Lighter density
    110: Darker density
    00 5, 4 Resolution 00: Standard
    01: Detail
    10: Fine
    01 1, 0 Original Type 00: Text
    01: Photo
    01 7 Home Position Off On
    02 0 Transmission stamp Off On
    02 1 Transmission mode Memory transmission Immediate transmission
    02 2 Label insertion Off On
    02 4 Auto Reduce Off On
    02 6, 5 Fax Header 00: Off
    01: On
    • Shadow
      • Sep 2011
      • 455
      thank you sandmanmac, much appreciated.
      if I had the ability I would give you rep points.
      • sandmanmac
        • 3981
        No problem. Anytime
        Yeah, what up with my "Rep button"? I noticed a while ago it wasn't there....figured it was just because it was my own account
        I may be on double-secret probation for being a bit if a shit disturber a few months ago.
        • femaster
          • May 2011
          • 1513
          Shows up for me. But I can't help you with the rep either; at least not yet...
          • Bantams
            • Jun 2012
            • 603
            No problem. Anytime
            you need to give in order to recieve
