Ricoh 2045e Tray 1 jamming (Lanier LD145, Gestetner DSM 645) Tray 1 jams
  • mailderrick
    • Mar 2010
    • 131
    This one is the gestetner version and tray 1 is jamming. The first time i went up i checked rollers (i just put in a month or so before because they were complaining of jams) I cleaned rollers checked everything and it ran fine so i left. Then i got a call a day or so later that it is jamming again (they took paper out of tray 1 to continue running the machine). I went back up with a brand new feed clutch,separation torque limiter, and new rollers. I replaced all of them figuring that would take care of the problem. We ran about 100 pages and i left on friday (thinking it was fixed)and monday afternoon they let me know it still jams. What can cause tray 1 to jam that i have not already replaced?
    Any ideas would be appreciated.
    Thank you
    Derrick
  • teebee1234
    • Jul 2008
    • 1670
    It's not uncommon for the tray lift chuck to get a split that will widen as the tray rises, causing insufficient pressure of the paper against the pickup roller (especially with a full tray due to the weight of the paper). Pull the tray out and shine a light on the chuck in the rear of the frame. Chances are you'll see a crack in it.
    • femaster
      • May 2011
      • 1514
      Re: Ricoh 2045e Tray 1 jamming (Lanier LD145, Gestetner DSM 645) Tray 1 jams
      I'll +1 that. I've seen this on a number of different machines...
      • mailderrick
        • Mar 2010
        • 131
        Thanks, none of you happen to know the part number of hand, do you?
        • teebee1234
          • Jul 2008
          • 1670
          AX04 0078
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Athlontini
              • Jun 2012
              • 269
              Is the tray paper size actually set correctly?
