ricoh scan to gmail
  • mavetherave311
    • Oct 2012
    • 11
    [Misc] ricoh scan to gmail
    when setting up scan to gemail on a ricoh copier,do yoU have to use SSL
    WHAT CAN BE DONE IF THE COPIER DOES NOT SUPPORT ssl
  • sandmanmac
    • 3981
    Re: ricoh scan to gmail
    It does not support SSl, and of course Gmail uses SSL. There is a program called "stunnel" that can be configured to funnel the mail through a gmail account and it works well, but it requires that the PC be on in order for it to work.
    Otherwise,You need to use the smtp settings of an account that doesn't require ssl - either an account from your isp, or you can setup a generic yahoo email account which i've done for several of my clients, since the machine just requires the proper credentials for the account, and no mail is actually filtered through the 'outbox" or anything. I'm able to use 1 account for several clients.
    2 notes:
    1: setup a xxx@yahoo.com account and not "@rocketmail.com" extension for example because I believe that one uses ssl, and
    2: for the smtp server, use the actual ip address rather than the 'smtp.mail.yahoo.com' (or whatever it is)
    • mavetherave311
      • Oct 2012
      • 11
      cheers ...thanks for the info
      • NeoMatrix
        Senior Tech.
        • 3513
        ping aspmx.l.google.com
        Pinging aspmx.l.google.com [74.125.25.27] with 32 bytes of data:
        Reply from 74.125.25.27: bytes=32 time=220ms TTL=44
        Reply from 74.125.25.27: bytes=32 time=221ms TTL=44
        Reply from 74.125.25.27: bytes=32 time=218ms TTL=44
        Ping statistics for 74.125.25.27:
        Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
        SMPT : aspmx.l.google.com
        port : 25
        < add user name and password authentication>
        All the above works fine for my gmail setup. I use these settings to test customers scan-to-email settings to gmail. Then I convert over to their proper email I.T. settings.
        Search the Copytechnet forums; I believe this thread was spoken about some time ago.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          port : 25
          Correct me if I'm wrong, but I'm pretty sure that SMTP will only allow you to send to others at Gmail, nowhere else.
          In addition to using Sandman's recommendation of Yahoo, I like to use GMX. Never an issue with it yet.
          • sandmanmac
            • 3981
            I believe I've heard that to be the case before, nevertheless, I've never been able to get those settings to work for me at all (here in Canada) for some reason
            • mavetherave311
              • Oct 2012
              • 11
              thanks for that....seems to have cured the problem
              port : 25
              • mavetherave311
                • Oct 2012
                • 11
                thanks for the reply...gmail requires SSL...however,i have received areply after going on google....without SSL authentivation,you can only scan to gmail,where as with SSL you can email everyone
                • jrattner
                  • Apr 2013
                  • 30
                  Was a solution to this ever found? Are your users able to send mail from their GMail accounts?
                  Justin
