Modification to the Gestetner DSM725 charge roller?
  • eddiep
    • Aug 2025
    [CQ] Modification to the Gestetner DSM725 charge roller?
    Every time we order the B205-0151 charge roller its different than the one in the copier.Did they make a modification to the charge roller or Drum unit?
  • Bantams
    • Jun 2012
    • 603
    Re: Modification to the Gestetner DSM725 charge roller?
    Nope the part number is still AD02 7018 but I find its more cost effective to replace the PCU with the type 2238 assy rather than rebuild them pn 411018 they usually do 80k with no problems
    • sandmanmac
      • 3981
      Damn Brain farts! I'm pretty sure you meant type 1027 PCU assy.
      And yes, 1027 PCU is definitely the way to go for (in Ricoh Terms) MP2510 / MP2550, etc.
      That would explain the different PCR. Similar assemblies but the charge roller is not the same, and is the P/N Bantams gave
      • eddiep
        Thanks Bantams, I don't know if its the same with British and American parts because our pn 411018 comes up as a type1027 its definitely cheaper. The other thing is I cant find anywhere it says you can use it in the DSM725.
        • Bantams
          • Jun 2012
          • 603
          Its the same pcu as the RexRotary 2238 gestetner 2212 ricoh 1022 trust me it fits we use them in all the russians from C2 to present models
          • eddiep
            Thanks guys,Ill differently use that part instead.
            • sandmanmac
              • 3981
              I think he was just confused by the cross-referenced model #'s in your first description as I eluded to in my initial response. Turns out I may have been too, because I don't ever use or see Rex rotary references
              • Bantams
                • Jun 2012
                • 603
                Neither do we anymore since Ricoh took over NRG we used to be a RexRotary dealer so sorry for the confusion.
                • collme
                  Ricoh tech
                  • 221
                  on russian c5 you need to do dev init as it does not do it automatically when you change to the consumer pcu unlike it does with the earlier russians. MP2550 is designed to have pcu overhaul so does not have the ability for new unit auto dev initialise
                  • collme
                    Ricoh tech
                    • 221
                    bantams, where do you work as only know sts as rex dealer who used to be up near airport and moved to wetherby.
                    • Bantams
                      • Jun 2012
                      • 603
                      Acorn Business Machines for the past 18 years there in Hudderfield
                      • collme
                        Ricoh tech
                        • 221
                        I know it, 2 names for you Paul Draycot and James Bunting. Worked with both of them at Alto. Sorry off topic.
                        • kannuki2
                          • Feb 2012
                          • 398
                          Okay, I don't know how is it cheaper. The PM KIT for B205 0151 consists of charge roller, cleaning blade, opc drum and order a b121 developer bag for a total cost of $140 for technicians. How much is that TYpe 1027 pcu?
                          The con of using Type 1027 pcu is be prepare to vacuum the toner inside of machine and laser unit after two months (frankly, it takes me almost 1.2 hour just to clean every toner off inside the machine and tray assemblies.
                          HOW IS THIS A COST SAVINGS?
