The pcu unit is getting full of developer everytime. What can I do?
Ricoh af-2045 - pcu with developer
hi
just see if the charge level is changing after 10 copies or if you locked the right door (1500v to 2000V)... -
Here are some additional checks:
(1) If you replaced the Drum did you do the following setups:
SP3001 ID sensor intial
SP2805 Developer Initialization (Also called Process Control on most copiers)
SP001-001 Charge Roller voltage to -1450 to -1500V
(2) The bias contact on the rear of the Drum Unit may be bent in, which will give you completely black copies.
(3) Is the Dev Ground Plate still in place. I have seen techs loose this part when replacing the developer.Comment
(3) Is the Dev Ground Plate still in place. I have seen techs loose this part when replacing the developer.sigpic
A+; Network +; PDI+Comment
Michael
pcu unit with developer
The sp-2001-001 values are changing from 1500V to 2000V everytime? What it can be?Comment
What does that mean, "it changes everytime"? Every copy? Everytime you look at it?
Developer bias can change whenever process control runs. Most of the time it will run from PM to PM at the default (1500) If it is going as high as 2000, you have something else out of spec. It could be anything listed in this thread.
Have you checked any of those yet?sigpic
if it changes every time after 10 copies from 1500 to 2000!! changes the maximum value 2000 to 1700 for example ,SP2 005 4 we have this problem after copying smc list, checking all sp with your manualComment
Michael
The sp-2005 -003 stopped changing but the machine still have developer in the pcu unit even after the unit was cleaned.
I changed the drum too.
If anybody have another idea, please, answer me.
thanksComment
How long has the developer been in there? If it has been or is undertoned, it will cause the symptoms you describe.
In the absence of anything else, I think I would CRAM the engine SP5801-2, replace the developer, run 2801, 2802, 3001-2.
Everything should be a factory specs at that point.
As has been mentioned make sure you are using the correct supplies.sigpic
