Ricoh 3260C Light prints all colors
  • mailderrick
    • Mar 2010
    • 131
    I have seen this happen once before on a amachine but the machine had so many other problems that the customer ended up replacing it (when a Xerox salesman walked in) before i was able to go in and figure out this particular problem. I now ran into the exact same problem on the Toshiba version of this same machine. All colors get very light and grainy. If the customer tries to do a color calibration in user tools it fails. I can get it to work by forcing a toner add for all colors and then if you calibrate it (when the colors are darker) of course it will then calibrate fine. The print is lighter than it should be though. The machine has a total of 59K color prints and 228K black. Doesn't sem to be very high for all colors to have a problem. Possible Drum issues (all 4?)? I am wondering if anyone else ran into this and what the problem may be.
    Thank you
    Derrick
  • sandmanmac
    • 3985
    Re: Ricoh 3260C Light prints all colors
    Must admit, I've never really laid my hands on one of these boxes, but according to "The Goose" there seems to be any number of causes for that condition, and a few bulletins (that I don't have access to) as well.
    B132/B200 Light copies replaced transfer belt and ID sensor
    B132/B200 LIGHT/FADED IMAGE adjust pressure springs on transfer roller - not in correct position refer to pg 3-67 SM
    B132/B200 LIGHT/FADED IMAGE Adjust SP mode 3171 lower for colors affected.
    B132/B200 Light/Faded Image adjust spring on transfer roller
    B132/B200 LIGHT/FADED IMAGE Clean toner build up on toner end sensor for that color subhopper ..
    B132/B200 LIGHT/FADED IMAGE Clear printer application, SP 5801-008..
    B132/B200 LIGHT/FADED IMAGE ID sensors to be clean as per BULLETIN NUMBER: D014/D015 - 025
    B132/B200 LIGHT/FADED IMAGE ID sensors to be clean as per TSB: D014/D015 - 025
    B132/B200 LIGHT/FADED IMAGE light copies on all 4 colors - replace developer
    B132/B200 LIGHT/FADED IMAGE Light copies only on black sug black toner hopper or clutch
    B132/B200 LIGHT/FADED IMAGE Light copies only on yellow - Replace yellow toner pump
    B132/B200 LIGHT/FADED IMAGE Light copies only on yellow. Suggest to replace yellow toner pump
    B132/B200 LIGHT/FADED IMAGE Low Humidity - Thick paper FC light areas - SP2541 - 017 - Set it to 85%
    B132/B200 LIGHT/FADED IMAGE Lower values in sp-mode 3531-1,2,3,4 and set sp-mode 3501-003 as 2.
    B132/B200 Light/Faded Image Perform ACC.
    B132/B200 LIGHT/FADED IMAGE Perform Bullentin 079 - Transfer bushings and rollers
    B132/B200 LIGHT/FADED IMAGE Poor connection at transfer p.p. - Reset all transfer p.p. connections
    B132/B200 LIGHT/FADED IMAGE Replace Black toner hopper assembly
    B132/B200 LIGHT/FADED IMAGE Replace Developer.
    B132/B200 LIGHT/FADED IMAGE replaced transfer belt and ID sensor
    B132/B200 LIGHT/FADED IMAGE SP modes 3501-003 set as 2, & Lower value in 3531 & 3551
    B132/B200 LIGHT/FADED IMAGE Unclog white rubber hose from toner cartridge to sub hopper.
    • Ricohguy
      • Sep 2012
      • 48
      MUSIC sensors are dirty. They are on the transfer belt unit and they get dirty VERY easily. Clean with a damp cloth(or you will be worse off then you were before)
      • Herostrat
        • Oct 2012
        • 220
        How about cleaning the lasser assembly?
        Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
        • mailderrick
          • Mar 2010
          • 131
          So with the description I gave, the fact that I can bring the colors dark enough to pass the calibration after 1 toner add and if I do a second and third they get darker but never 100%, Also given the page count, more likely a dirty sensor than all 4 developers bad or any of the other causes listed?
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • mailderrick
              • Mar 2010
              • 131
              BTW, It was the dirty MUSIC sensors. Took the belt out cleaned all of the sensors put it back in and it worked perfectly.
              Thank you to all who helped me troubleshoot this.
              Derrick
