The machine was dead during my first visit and I pulled out the power supply unit for repair. After it was repaired, I fitted the power supply unit. The machine went on and paper jam error showed in the display. I checked the place where paper jammed. I found two papers jammed in the fusing and registration section. After I removed those papers, I then closed the side door unit. Suddenly, the machine went off. The power supply unit was damaged again.
Have you encountered this kind of problem?Which part is faulty? I am afraid that if I fit the power supply unit it will be busted again. Do you think it is grounded?
Which component in the power supply is damaged in this case?Fuses are all good..
