MP3352
  • tludden
    • Oct 2011
    • 7
    MP3352
    I have an MP3352 getting light washed out looking copies. Prints look fine. I did drum, developer, primary and SP2801 but no luck still washed out looking. I have the primary for copying maxed out just to make the copies look good??
    Any suggestions?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP3352
    If prints look good, I would focus on scanner optics.
    • sandmanmac
      • 3981
      Re: MP3352
      x 2 on the scanner optics. You didn't mention doing them, and that should be the first thing you do when prints are fine and copies washed out. It's certainly not a dev/drum problem if prints are ok
      • tludden
        • Oct 2011
        • 7
        Re: MP3352
        I did clean the optics. I am ordering a LED assembly hoping that will do it.
        • Bantams
          • Jun 2012
          • 603
          Re: MP3352
          If its somewhere really Cold it could be condensation building up in the Optics If that's the case its going to need the anti condensation heater fitting.
          • kannuki2
            • Feb 2012
            • 398
            Re: MP3352
            Try to make a copy in 50% reduce and enlarge images to see if the density changes. It could be a tilt in the optic mirror.
            • Ollie1981
              Toner Monkey
              • Mar 2008
              • 417
              Re: MP3352
              Run Sp5990 - 06 Non Default and compare all values with the "Birth Certificate" which if you are lucky should be under the laminated card in the front door.
              Had this problem a couple of times where the scanner gamma settings were all out of whack, dunno why, but re-inputting the values on the birth certificate brought the CQ back.
              If it keeps forgetting them, it'll need an NVRAM
